2001 ebcm
Sent to ABS fixer. Re solder and cleared codes. Still an error message. NO COMMUNICATION. Talked to them and said unit checked out ok. I inspected both connector harnesses for bent pins etc. Replaced both 20 and 40 amp fuses, even though they appeared ok. Any suggestions fo anything I might be missing? Both panel lights are still on.
Welcome to the forums. The only problems I have had with ABS systems was with the wheel sensors, where the harness connects from the chassis to the wheels, bad connections. Cleaned them and reinstalled they worked fine after that. Check and clean all contacts and hope for the best. getting a good affordable replacement these days might be a challenge.
Sonia1964
May 22, 2022 03:38 PM
SpeedyKev64
Apr 13, 2014 05:08 PM
