450HP pump gas SBC
Complete 385 Stroker Engine
What is included:
450HP 385cid Chevrolet small block
Flowtech headers with custom collectors
Meziere 55gpm street/strip electric water pump
Internal Specifications:
Block: Seasoned 4-bolt GM 010 Casting (2pc rear)
Crank: 3.75" Eagle Cast Steel crank
Rods: 6.0" Forged crower sportsman
Pistons: 4.040" SRP forged 1/16" Ring design
Gaskets & Bearings: Clevite & FelPro
Cylinder heads: 200cc Sportsman II iron heads
Intake:Edelbrock RPM
Camshaft: Crower solid flat tapped 242/248 duration
Oil System: Milodon pan, P/U, and Melling Pump
Timing Chain: Cloyes True Roller
Valve Covers: Moroso with moroso breathers
Valve train: Crower stainless Roller rockers & Comp heavy wall Pushrods
Balancer: Pro.Series External balance
Flexplate: External balance SFI
Machine work and assembly performed by Windsor Automotive machine.
This engine is nearly brand new, and was built entirely with brand new parts (Except the block), after a handful of drag strip passes, and 3000 street miles its being replaced by a big block.
Take advantage of an excellent deal which includes the Headers exact combo (Capped with exhaust!) has gone 11.15 @ 117.
Hear the engine run prior to purchase, and i will remove the engine at the time of purchase.
NOT INCLUDED:Alternator and bracket, crank pulley, Distributor, Starter, carb, carb spacers.
$3,450
Interested in Stacks of Paper ONLY, no trades.
What is included:
$3,450
"$3,450
Interested in Stacks of Paper ONLY, no trades. "
does that paper have to begreen? cause I got box loads of white. LOL
seriously...where are you located? and what is it in now?
Neptunati
Aug 7, 2006 12:39 PM
