Gas pedal stuck
Gas pedal stuck
I punched the gas pedal off the line and she got stuck.I turned the key off and pulled over safely.After several attemptsto clear the pedal i started the car and was doing 30 mph without touching the pedal.Then two minutes later she went back to normal.I see some wear on the cable at the fire wall.Anyone else have this problem or solution? (84 vette C4)
