Gas pedal stuck
Old May 15, 2006 | 12:28 AM
Viscito's Avatar
Default Gas pedal stuck
I punched the gas pedal off the line and she got stuck.I turned the key off and pulled over safely.After several attemptsto clear the pedal i started the car and was doing 30 mph without touching the pedal.Then two minutes later she went back to normal.I see some wear on the cable at the fire wall.Anyone else have this problem or solution? (84 vette C4)
Old May 15, 2006 | 09:36 AM
Default RE: Gas pedal stuck
Either your throttle linkage is rubbing on something or cable is binding. Check the operation of both throttle bodies for smooth action.
Old May 15, 2006 | 02:29 PM
corvette king's Avatar
YA, SHURE SOUNDS LIKE CABLE ,CHECK YOUR BRACKETS TO
chuck
Mar 7, 2010 05:42 PM
jsholm2
Apr 13, 2008 09:49 PM
PopPop
May 21, 2007 10:03 AM
mikenann
Nov 16, 2006 08:10 PM
mypetu39
Sep 12, 2006 11:43 AM
