cooling/oil light problems
Old Feb 14, 2009 | 08:03 PM
brewman68@msn.com's Avatar
Default cooling/oil light problems
A) I have a 91 six speed C4. the fans wil not turn on unles the a/c is on??? (B) How do you reset the change oil light ??? Thanks al!!!
Old Feb 15, 2009 | 02:18 PM
partsman41's Avatar
Default cooling/oillight problems
Sounds like maybe your fan sensor/switch is bad. I'm not sure but I think the same relay turns the fan on when you go to AC as turns it on when the switch calls for cooling.To reset the change oil,turn the key on and depress the gas pedal 3 times in less than 5 seconds. This works for all the GM's I know of.
Ron
dale
Aug 29, 2015 11:09 AM
93c4matt
Sep 17, 2008 12:16 PM
delaughter68
Nov 21, 2007 06:33 AM
bigjohn
Apr 4, 2007 12:04 AM
joecls
Apr 18, 2006 11:57 AM
