powerglide leaking late
Old Mar 5, 2006 | 11:44 AM
muscle car's Avatar
Default powerglide leaking late
Hello corvette forums.heres my problem,I have a 67 corvette conv. w/ the factory 2 speed powerglide.the car has completely retro restored to MY specs.and taste.multiple super chevy award winner for best corvette in show as well as best in class.I am very picky when it comes to my car.Anyway...The car runs and performs perfectly w/ the exception of the powerglide.It also runs great except after running for even a little while and shutting it down,it leaks trans fluid on my garage floor after the 2nd. day of shut down a spot about 4" circle directly under the drivers side front corner of the drain pan.I had it totally rebuilt professionally about 1 year ago by the owner of a local transmission shop who also owns top shelf musclecars.(show condition).I have not contacted him yet on this,thought I would ask all of you first to get opinions before I called.
Old Apr 2, 2018 | 02:24 PM
Rick Rain's Avatar
Smile leak
If its leaking around the shift shaft, I have a great solution
Old Dec 11, 2022 | 07:38 AM
Ballroom's Avatar
Default Tranny leak at shift shaft.
hi Rick
wjat is your great solution?
Old Dec 12, 2022 | 10:08 AM
Muscle Car and Ballroom: Welcome to the forum.
Old Dec 16, 2022 | 04:29 PM
ACYtower's Avatar
My 66 Powerglide had a big leak out the back. Well I tore the car apart and ordered several different brands
of rear seals to put in. I used the one that looked the best by my eyesight. I also used a sealant around the
flange. I haven't finished the car yet. Have several months to go on it. But I hope this does the trick.
Good luck.
Butch
Jersey shore
C5VetteGuy
Dec 19, 2017 08:09 AM
Trooper
Aug 8, 2010 05:10 PM
noreason
Dec 10, 2007 08:28 PM
davedanisand
Oct 16, 2006 09:58 AM
rowdog_14
Oct 5, 2006 12:52 AM
