86 Antenna Motor
Old Jun 11, 2007 | 10:13 PM
HDMark's Avatar
Default 86 Antenna Motor
I need two different things.
A good local Northern Virginia Corvette Mechanic in case I need one. Also an antenna motor. I have searched Ebay anddon't see any available,
Thanks for your time.
Mark
Old Jun 12, 2007 | 06:21 AM
mypetu39's Avatar
Default RE: 86 Antenna Motor
HDMark,five yearsago, when I took my 87 Vette conv't out of Winter storage, my antenna would not operate. I could hear the motor working(humming), but the actual antenna would not move. I searched around for a replacement, but was hard to find, even on eBay. I took a can of WD-40 and sprayed half of it down the antenna hole in the body of the car and let it sit for a few hours. Then I emptied the can down the hole and the next morning, I turned on the radio and the antenna worked perfectly; no problem since. TRy this and it may surprise you, unless the motor is actually burned out.
mypetu39
Old Jun 12, 2007 | 12:32 PM
seen_alot's Avatar
Mid America has both the complete motor and just the replacement mast with the nylon ribbion attached.
If the motor is working, replacing the mast and nylon ribbon is easy
Old Jun 16, 2007 | 05:34 PM
HDMark's Avatar
Thanks for the information. I will try both!
94blackC4
May 19, 2006 11:36 PM
Boshaft
May 18, 2006 04:00 PM
Vet Head
Oct 13, 2005 11:09 PM
jafone
Jul 19, 2005 03:24 PM
jafone
Jun 22, 2005 08:20 PM
