94 Antenna Cable ?
Thanks for the quick reply. Ihave the antenna adapter. But theres not even a place on the factory stereo I just removed for a antenna, just the wiring harness. The factory stereo is a Bose Gold Series Model 16172721 if this helps. I just relized that I bought the wrong wiring harness too. I bought the Metra 70-1858 which is wrong, it won't hook up to the car harness. Now I need to find out which wiring harness is right. I am changing the speakers also so I wont be using the spearks amps.
Thanks,
Steve
Thanks,
Steve
Well I just got the Metra 70-1857 in today. Its wrong also. I sure would like a little help here. I getting tired of wasting money. The wiring harness plugs of both wiring harness are no where what I need.
Come on guys a little help,
Steve
Steve
you have to find the tuner pack in the dash board...your antenna and your plug in for the metra 70-1858 harness are at the tuner pack. it is usually located on the passenger side of the car under the dash forward and to the right. thats where your power and amp turnon leads are as well as the antenna lead.
