cable lube... YUK
Old Jul 2, 2007 | 07:33 PM
Default cable lube... YUK
I did the lawn mower thing this AM, to include maintenance. As well we had to lube the throttle and cut-off cables. What a gargantuan pain. However, I figured out a little trick, which I'll try on my hood cable release.
I'll get a pic to show later. Here's a description in the meantime...
I disconnected one end of the cable, pulled up a little slack of the cable from the sleeve, then I sprayed some super penitrant lube into an armor-all cap.
Next, put a section of snug-fitting rubber hose around the end of the sleeve, slide it just above the end of the sleeve, to make a sort of 'cup', and then pour the lube in. It will drain into the cable, and pretty soon, you can work the cable up and down in the sleeve with your fingers.
A word of warning: get some rags under the low end of the cable as you do this. You won't believe the jam that comes out of the cable low end. And what a difference a slickcable feels like!!!
As much a pain as it was, I bet it don't even compare to a broken cable... Anyone been there before?
Old Jul 3, 2007 | 09:05 AM
riley's Avatar
Default RE: cable lube... YUK
Yeah, motorcycle (especially dirt bike) guys have been dealing with dirty cables for a long time. I've got a special tool for lubing cables. It does almost exactly what you are talking about, except it encloses the end so that you can use a spray like WD40 and it gets forced down into the cable. Just Google "cable lube tool" and you'll find links to several of these. I've been using one of these for years on my clutch and throttle cables and it works great. This is the one that I use: http://www.motionpro.com/motorcycle/cables/cable_luber
Old Jul 9, 2007 | 12:04 PM
ORIGINAL: riley
DANGIT!!!
THAT'S MY IDEA!!! I want $$$!!!
Old Jul 14, 2007 | 03:51 PM
Notorious's Avatar
That's a damn good idea. I always applaude well thought out ingenuity.
Old Jul 14, 2007 | 09:08 PM
78buckshot's Avatar
Been using the cable lube adapter that Riley uses since the early '70's, just like he said, the dirt bike gang needed somthing to force all the sand and water out of the cable.
bigtalos
Dec 15, 2010 07:34 PM
whipperdecon
Sep 17, 2008 12:08 AM
imb1987
Oct 30, 2006 03:22 AM
taz7nads
Sep 7, 2006 11:37 PM
Gkayea
Nov 18, 2005 11:32 PM
