1965 heater blower motor
Old Nov 1, 2007 | 12:02 PM
wew1139's Avatar
Default 1965 heater blower motor
I am having a problem with the heater blower. Replaced blower motor.(old one did not run) Now after checking circuits, switch, grounds, etc. it will run then shut off. If I replace the fuse, it will run and shut off ( fuse tests ok). I have replaced the rheostat in the heater box to no avail. Any suggestions? THANKS EVERETT
Old Apr 12, 2008 | 07:25 AM
wew1139's Avatar
Default RE: 1965 heater blower motor
Found the problem with the blower motor. It eventually lead to other electrical "glitches." The whole problem stemmed from a corroded fuse block, connections, fuse terminals,etc. Replaced fuse block. Everything seems normal now. Just thought I would pass this on FYI.
Old Apr 12, 2008 | 08:16 AM
extanker's Avatar
glad ya found it. many thanks for getting back and letting us know
MarksGoldie1986
Oct 30, 2013 09:31 AM
srgord
Oct 4, 2008 05:42 PM
ShadowF1
Jan 27, 2007 04:00 PM
crankyyank
Oct 2, 2006 08:55 PM
dilling
Nov 29, 2005 12:49 AM
