65 Vette - interior dash lights are too dim
Old Nov 24, 2019 | 08:44 AM
MC 65's Avatar
Default 65 Vette - interior dash lights are too dim
All of my dash lights work but are too dim. Should the reostat on the light switch be replaced?
If so is this a simple swith change or does the dash need to be opened up?
Thanks for any assistance.
Old Nov 26, 2019 | 04:09 PM
It's been a while since I worked on a '65 but I suspect that you need to be able to access the rear of the switch in order to release the shaft/**** and remove the switch. You could try to jumper 12 volts to the lites. It also could be that the bulbs are old unless they've already been replaced.
VETTEC599
May 12, 2013 10:56 PM
Catman87
Apr 27, 2009 01:22 AM
1974corvetteowner
Nov 27, 2007 07:31 PM
IVAN1215
Technical Diagram Help
Sep 24, 2007 01:50 PM
yuggster
Jun 17, 2006 02:15 PM
