Hot air coming into drivers side
Old 06-12-2018, 09:39 PM
KTimen's Avatar
Default Hot air coming into drivers side
Have a 64. I get a lot of very hot air coming into the drivers side . The passenger side is cool. The fan and heat seem to be off but it’s really hot when the car heats up. The dash was recently replaced. Possibilities ?
Old 06-13-2018, 09:20 AM
Is the hot air coming through the kick panel vent or the heating system?
Old 06-13-2018, 09:06 PM
KTimen's Avatar
Default Not sure
We’re trying to figure it out. The drivers floor vent is missing the control. Which I have on order. Then the next thing is going to be is trying to figure out if the heat continues then it has to be the heat from heater core . Ever come across this ?
Old 06-14-2018, 11:01 AM
My only mid-year experience was with a '66 big block roadster and they are hot all the time. If it's not the kick panel vent then the next thing to check is the blend door which may require removal of the dash again. If that control cable is not connected, then that could be the source of your heat.
Old 06-14-2018, 12:04 PM
KTimen's Avatar
Can't get to blend door without pulling the dash?
Old 06-14-2018, 08:52 PM
Honestly I don't remember and my friend sold his 66 a few years ago. You can look under the dash and see if you can reach it or possibly pull the glove compartment box and maybe get it through there.
Dolittle
03-01-2016 07:03 PM
ryhton
05-28-2012 12:28 AM
riley6riley
06-24-2008 09:37 AM
EC15
05-07-2006 02:00 PM
BBPREPRO
06-29-2005 07:31 PM
Quick Reply: Hot air coming into drivers side
