75 rear end
Old Dec 21, 2007 | 10:05 PM
bushwacker's Avatar
Default 75 rear end
has any body ever replaced the irs with a 9" ford and coil over shocks, i really dont want to go as far as doing a back half frame job, just want to get rid of all the joints. any help would be appreciated. thanks. mark.
Old Dec 21, 2007 | 11:06 PM
Default RE: 75 rear end
Welcome to CF. I remember reading back in my younger days about guys doing just what you mentioned for drag racing cuz the IRS just wouldn't take the abuse. Haven't seen anything recently tho but there's plenty of folks on this forum that probably can help you.
Old Dec 22, 2007 | 12:30 PM
Texas Jim's Avatar
The Ford 9" has been used in alot of things over the years, from drag racing to lowriders, because they're so strong. With a Detroit Locker, they're ready for alot of abuse. (some of the 9" housings can take a 9 1/4" ring gear as the housing is slotted inside-I have one in my '62 p/u) If you're going to drag race, it'd be worth it, but if just for the street, I'm sure you can make the independent set-up work well, even with worked big block HP. Check out what the mid to late '60s 'Vettes w/ 427s used in the factory set-up.
Good Luck, sounds like you're building a "For Real" 'Vette.
supermano57
Nov 21, 2005 10:44 PM
way235
Nov 10, 2005 04:14 PM
Kyle93
Oct 19, 2005 11:26 PM
nmoser01
Sep 6, 2005 06:13 PM
jerrys
Corvette C6 Z06
Sep 3, 2005 07:13 PM
