80 body sits lower on passager side
Old Jun 30, 2006 | 03:02 PM
Pistol Pete's Avatar
Default 80 body sits lower on passager side
Just bought my first Vette (1980), the body seems to be lower on the passager side by about 3/4". The space between the top of wheel well and top of tire is where it is most noticable. The rear body mount needs replacing (passanger side), but the front is actually worse then the back as far as alignment. What should I be looking for to fix this. Any help would be appreciated.
Old Jul 9, 2006 | 04:29 AM
yuggster's Avatar
Default RE: 80 body sits lower on passager side
I to would be interested in an answer to this. I just bought my 80 and I have the exact same thing only the driver side sits lower.
Old Jul 9, 2006 | 05:01 AM
R Rocks's Avatar
Body Squareness. This could be a sign that the car may have been repaired, a inch or more of variation is probably due to weak springs. John Pfanstiehl
Old Jul 13, 2006 | 02:57 PM
Thanks for your reply.
When you say the car may have been repaired, what repair would cause this? Is it safe to say it is probably the spring and if so do you have to replace both springs at the same time?
Old Jul 13, 2006 | 10:15 PM
R Rocks's Avatar
Feel around the lip of each wheel well for evidence of repairs, most common on the front fenders. Quickie crash reairs are often done by splicing the fender in the middle insted of replacing the complete panel. Patches of fiberglass matting and lumps of filler material are the giveaways. John Pfanstiehl. Replace both.
Old Jul 14, 2006 | 11:45 AM
Thanks John, you've been a lot of help, being a new Vette owner, I just wanted some advice so I don't get taken to the cleaners on this repair.
Have a great day!!
Old Jul 14, 2006 | 09:39 PM
tommytunes's Avatar
first thing todo would measure the lower a frame to a spot on the frame.with weight then without weight.they should be the same length on both sides.if you have differnt length without weight theres a twist in frame.
Old Jul 17, 2006 | 02:55 PM
Thanks for your reply. I don't quite understand where on the frame I need to measure. Can you elaborate at all?
Old Jul 19, 2006 | 08:38 PM
tommytunes's Avatar
jack up car take front wheels off.find differnt points to measure.take some time looking
and measuring many places.it could be body mount,weak spring,a arm bushing,a tweek
in the frame.my guess would be bad body mount,thats a fast fix.is it lower at bumber or behind front wheel.take a look at the mounting of lower a arm they rip off frame.only two spot welds hold it on.also very fast fix.i fixed 2 of these already.20 min weld job for both sides.this should be checked any way.
Old Jul 20, 2006 | 12:16 PM
Thanks so much, good info. Have a great day.
pegasuspup
May 14, 2022 01:48 PM
remember5
Aug 17, 2008 08:56 AM
seen_alot
Jul 26, 2006 03:55 PM
july349
Oct 14, 2005 07:27 PM
july349
Oct 8, 2005 02:01 AM
