81 vette horn doesn't work
Old Jul 9, 2006 | 04:22 AM
fraunz's Avatar
Default 81 vette horn doesn't work
When I press the horn button I hear a niose at the fuse box. No power to the horns. Is there something that has to be replaced in the fuse box?
Old Jul 9, 2006 | 05:10 AM
R Rocks's Avatar
Default RE: 81 vette horn doesn't work
Relay, less than ten bucks. You can pull this out, open it up and clean the contact. looks like a set of points inside. Mine was not at the box but near by.
Old Jul 18, 2006 | 03:48 AM
fraunz's Avatar
fixed,Thanks!
Old Jul 21, 2006 | 02:40 PM
herron's Avatar
I don't hear a noise when I try to use the horn...I hear nothing at all. Could be the horns, could be the relay switch, could be the fuse. Problem is...where are ANY of those? I'm assuming the relay is somewhere under the dash...is the fuse panel there, too? Which fuse is the right one? (I'm hoping they're labelled, but the picture in the 81 Manual is so small you can't read it)! And where exactly ARE those horns? I can't find anything that looks even remotely like one under the hood! [sm=insomnia.gif]
Dadsvette
Jul 10, 2013 10:10 PM
max
Oct 8, 2012 06:16 PM
77corvette
Sep 2, 2009 06:36 PM
avgjoe
Sep 11, 2008 09:37 AM
Marv5439
Oct 29, 2005 11:51 PM
