81 vette horn doesn't work
I don't hear a noise when I try to use the horn...I hear nothing at all. Could be the horns, could be the relay switch, could be the fuse. Problem is...where are ANY of those? I'm assuming the relay is somewhere under the dash...is the fuse panel there, too? Which fuse is the right one? (I'm hoping they're labelled, but the picture in the 81 Manual is so small you can't read it)! And where exactly ARE those horns? I can't find anything that looks even remotely like one under the hood! [sm=insomnia.gif]
