Bilstein shocks
Old Oct 29, 2008 | 06:39 PM
Mrjack's Avatar
Default Bilstein shocks
Bought a set of Bilstein Sportshocks for the '73 (front). Has anyone done this install, and if so, were there any problems with the install or the performance of the shocks?
Old Oct 29, 2008 | 08:40 PM
Default RE: Bilstein shocks
Welcome to the Corvette Forum. Shouldn't be any installation problem if they're the correct shocks. Just remove top nut (may have to hold shaft if it turns) and two cap screws on lower A-arm. Haven't personally used Bilsteins but hear that they are good.
Shouldn't you put a pair on rear to maintain handling balance?
Old Oct 30, 2008 | 06:23 PM
Flying Low's Avatar
ORIGINAL: 73shark
73SHARK has a good point. Those are great shocks, but you will see a much larger improvement if you replace them all.
I dont know how much trouble the rear are to replace but I'm sure it would be worth it, and it would help your vette reach its full potiential. Performance = fun [sm=badbadbad.gif]
Old Oct 30, 2008 | 09:20 PM
Only problem you run into with the rears is the upper bolt is usually rusted to the sleeve in the rubber shock bushing and can be a real PITA to remove after you get the nut off. Suggest soaking with Kroil a few days ahead of time.
Old Oct 31, 2008 | 02:52 PM
Mrjack's Avatar
Thanks for the info, I'm looking forward to the improved handling. And yes, I'll replace the rears also along with heavy duty front springs and a rear sway bar. However, these things have to be done over a period of time and with finese to prevent triggering the wife's hair trigger spending alarm! Again, thanks.
Old Oct 31, 2008 | 07:31 PM
For a small block and fairly neutral handling, recommend the 1.125" front bar and the 9/16" rear, 7/8" rear for a big block. Since it's neutral, you will need to be careful since the stock setup has quite of bit of understeer as do most cars. Lot safer to plow thru the corner going forwards than to have it swap ends.
Old Nov 11, 2008 | 03:22 PM
DeeVeeEight's Avatar
Banned
I have a pair of Bilstein Sports on the rear of my '79, along with a 400 lb. composite monospring - the improvement in handling is fantastic. I will be adding a pair to the front soon. The Bilstein's really firmed up the ride.
[sm=icon_cheers.gif]
shoxguy
Jun 27, 2011 07:28 PM
brewman68@msn.com
Mar 31, 2010 03:37 PM
jph
Jul 17, 2007 08:36 PM
TealC4
Dec 8, 2006 04:04 PM
mxw128
Jun 30, 2005 04:41 PM
