Brake Bleed
Old Apr 30, 2021 | 05:14 PM
RatFink60racing's Avatar
Question Brake Bleed
Help....I own a 1981 vette(recently bought). My brake pedal is soft and goes all the way to the floor. I have tried every method of bleeding the brakes, I even bought the Motive Power Bleeder. I don't see any air in the lines, no leaks. But the pedal is the same. I really don't know what else to try. Could the Master Cylinder be bad? There is no fluid leaking around it? Short of taking it into a brake shop I really don't know what else to try. Any ideas?????
Old Apr 30, 2021 | 08:39 PM
74HARLEY's Avatar
Sounds like a bad master cylinder to me.
Old May 1, 2021 | 09:33 AM
I will try that...The pedal is hard until I start the car..then I can put it to the floor.
Thanks
Old May 1, 2021 | 12:57 PM
Welcome to the forum. You could do a vacuum test on the power brake booster. You can also just pull the hose off and plug it and see if it still goes to the floor when you start it.
Old May 1, 2021 | 07:51 PM
Thank you..I will try that
Old Jun 8, 2021 | 12:49 PM
Help Please.... On my 81 vette I had brake pedal that went to the floor. Bleeding the brakes didn't help. I replaced all 4 calipers and a new master cylinder. Still had no brake pedal. SO..when I take the hose "off" the brake booster (the cars rpm goes up a little, BUT when I push on the brakes I have a hard pedal. " Does this mean the brake booster is bad??" There is good vacume coming from the engine hose. Do I need a brake booster or is it from something else..Thank you
Old Jun 13, 2021 | 09:02 PM
Certainly looks like it.
It sounds like you might be running a little rich since the idle increases when you add more air to the system.
ghia1974@comcast.net
Jul 23, 2019 08:14 AM
SuperHeroSmurf
Feb 12, 2012 01:53 AM
dr_maddox
May 9, 2009 07:25 PM
Flying Low
Nov 30, 2008 10:49 AM
alive69
Aug 8, 2007 10:04 AM
