brake rotor removal
Old Jan 19, 2009 | 08:20 AM
budman30562's Avatar
Default brake rotor removal
rotors wont come off been reading posts if i am reading right i have to drill out rivots r rivets in the 2 extra holes on the rotor or somewhere else thanks
Old Jan 19, 2009 | 09:36 AM
Rich G.'s Avatar
Default RE: brake rotor removal
I assume you are talking about the fronts. Works real easy on a drill press. Hit the rivets with a center punch first to make it easier.
Old Jan 19, 2009 | 09:59 AM
actually they r the back rotors got caliper off am i missing something else the guy at auto parts store said there was a screw in 1 of the 2 holes holding rotor on but no screw
Old Jan 19, 2009 | 10:29 AM
partsman41's Avatar
Possibly a couple of things. Is the emergency brake totally released? That will hold the rotors on or they're a little rusted around the center register. Soak around there with PB Blaster or WD-40 for a while then do some judicious tapping around the register and maybe a little in the off direction around the rotor.
Ron
Old Jan 19, 2009 | 01:24 PM
flyboy1024's Avatar
take the whole wheel hub off and drill from the back then take a air hammer to hit the heads off and hit the rivets through, if you dont have an air hammer u can grind the heads off with a small ginder....its much easier if u take the whole wheel hum off though....
Old Jan 19, 2009 | 05:20 PM
pg's Avatar
ORIGINAL: budman30562
The holes in the rear rotors are there so that you can adjust the parking brake.
Mark one lug and mark the hole it goes in if you are going to resurface and reuse the same rotor or you may have run out problems.
heres a link on rotor replacement.
http://www.corvettemagazine.com/tech...-overhaul.html
PG.
Old Jan 19, 2009 | 05:58 PM
kept reading found out drill orignal rivets these r the holes in the middle of every other stud with 3/8 drill bit get a pulley puller from advanced rotors popped right off no heat Good thing i did not take an air hammer to it just kidding thanks guys
Old Jan 19, 2009 | 08:01 PM
flyboy1024's Avatar
guess uve never used an airhammer to get rivet off, u dont use it to beat it out, u use it to push the head off, after u have drilled a hole in it to weakin it.... i did it to mine didnt damage a thing.....
najaf4life
Oct 18, 2008 06:52 PM
Ravensfootball
Feb 10, 2008 11:25 PM
gracing76
Feb 1, 2007 01:01 AM
LT4Dave
Dec 11, 2006 04:26 PM
cboegoforth
Aug 12, 2006 10:21 PM
