Distributor or Cap and rotor?
Old Dec 9, 2006 | 04:14 PM
LT4Dave's Avatar
Default Distributor or Cap and rotor?
Getting ready to repair oil leaks on front of my LT4. When I'm in there I'm gonna replace some stuff like plug wires and so on. Should I replace the whole distributor or will a cap and rotor be OK. 57,000 miles on this ride. What do you guys think?
Old Dec 9, 2006 | 06:26 PM
Default RE: Distributor or Cap and rotor?
Depends on if your distributor has the vent built in it. If it does, just replace cap, rotor. If not, then the updated distributor and while your there replace water pump also. [8D]
Old Dec 9, 2006 | 10:24 PM
corvette king's Avatar
I WOULD DO IT ALL SINCE IT IS ALL APART.....DO IT RIGHTR THE FIRST TIME
Old Dec 10, 2006 | 12:10 PM
JoeVetteman's Avatar
Some of them may have what I believe to be a vent,some don't.But,just to be sure,why not change it all and have a fresh start?And while you're at it,the water pump should be replaced as well.It is,after all,kind of in the way,so it could be a good time to change it.Good luck!
Old Dec 11, 2006 | 12:25 AM
raisinbran's Avatar
Since you have a '96, you already have a vented opti.
Old Dec 11, 2006 | 04:26 PM
LT4Dave's Avatar
Thanks guys. I'm on it!!!
[IMG]local://upfiles/3556/1FCDB34E48E84213A659D9307BB1933B.jpg[/IMG]
camhar25
Feb 2, 2009 07:25 AM
PsychoKimmy
Oct 8, 2008 12:34 PM
Dogcow750
Aug 28, 2007 11:23 PM
giostra
Jul 14, 2007 12:49 PM
hmclktmtn@msn.com
Nov 7, 2006 04:32 PM
