C3 Floor Pans
Old Aug 15, 2023 | 01:42 PM
sjburnsy's Avatar
Default C3 Floor Pans
I have a 76 C3 that went o the assembly line in 75. It was finished in 76. The floor pans are half fiberglass and half metal. The metal is were the seats sit. That portion is rusted out. The front is fiberglass. How can I fix this and has anyone seen this before?
Old Aug 16, 2023 | 07:17 AM
74HARLEY's Avatar
Could you please post pictures.
Old Aug 16, 2023 | 07:23 AM
Welcome to the forums. Yes this is a common problem with C-3's and most steel floor vehicles in high moisture areas. You can replace the floor pan or cut out the bad sections and section in new metal. You can also remove the metal and use it to mold a fiberglass section to replace the metal section. You have options.
Old Aug 16, 2023 | 06:17 PM
Old May 5, 2025 | 12:39 PM
sjburnsy's Avatar
Thank you, so you are saying I can make the entire floor made of fiberglass? Sorry it took so long to respond
Old May 5, 2025 | 03:16 PM
If it still has the catalytic converter, I wouldn't recommend removing the metal. You might be able to find a replacement metal floor pan from a donor vehicle from a place such as Contemporary Corvettes salvage yard in Pennsylvania.
Old May 12, 2025 | 10:30 AM
sjburnsy's Avatar
Thank you for the information. I have just purchased the floor pan I need.
Old May 12, 2025 | 11:23 PM
Let us know how it works out as your experience may help others down the road.
AGVI
Jan 11, 2023 09:00 PM
coy_staen
Dec 15, 2021 07:34 AM
fastfishel
Dec 3, 2009 06:18 AM
blueshark
Apr 26, 2007 10:50 AM
BluBeaSSt
Mar 16, 2007 09:49 AM
