Can't locate this part!
Old Sep 14, 2008 | 09:24 AM
glenn357's Avatar
Default Can't locate this part!
I'm a first time vette owner and have an 82 CE. Under the hood there is a damper door that allows air into the top of the air breather. The damper has an electric actuator that is bad, but I can't find this thing anywhere on the net. Does anyone know what this thing is called or where one can be purchased? Thanks!
Old Sep 14, 2008 | 04:23 PM
YANKEECORVETTE's Avatar
Default RE: Can't locate this part!
Do you have any part numbers and manufacturer stamped on the old part?
Old Sep 14, 2008 | 09:58 PM
Welcome to the Corvette Forum. If it's like the one on the cowl induction on the '73-'74s, it's a solenoid actuator. Searched several vendors w/ no luck. Maybe vacuum actuator. Might try a Chevy parts man.
Old Sep 15, 2008 | 04:13 AM
Texas Jim's Avatar
SHARK has a good idea. Go to a Chevrolet dealer and let the parts department guy look it up on the micro fish. You can get the correct "noun nomenclature"(part name)-sorry, that comes from the military years LOL-and then check out the aftermarket companies. Good Luck.
Old Sep 15, 2008 | 08:29 PM
DeeVeeEight's Avatar
Banned
It sounds like a 12 volt "solenoid" is what you all are describing. Find an old photo copy machine somewhere and scavenge one out of it or go to an electric component supplier and ask for one. They are more or less universal in their applications. It is an electro - magnetically activated plunger.
[sm=icon_cheers.gif]
Old Sep 15, 2008 | 09:34 PM
Might also see if you can see an '82 at a Corvette show. There's also a guy at the factory that ran a tech hotline named Gordon Killebrew. Think he's retired now but still maintains the service. Do a little digging and you can probably find him. Try the NCM.
Old Sep 17, 2008 | 12:25 AM
wrwalke's Avatar
Idle air control valve (IAC)? That is the only piece I can think of that might fit your description... Ecklers carries them:
http://www.ecklers.com/product.asp?p...p;dept_id=1183
bill.
Carl Parker
Sep 24, 2011 09:38 PM
my76toy
Oct 31, 2007 06:04 PM
Pecemkr
Oct 12, 2006 06:49 PM
94C4
Oct 1, 2006 11:30 AM
tonyrbp
Aug 14, 2006 02:08 AM
