Crate Engine for '75 Stingray
Old Feb 12, 2007 | 09:32 PM
  #11
Default RE: Crate Engine for '75 Stingray
Fram CA326. You can check other mfg. equivalents at your local parts store or maybe on-line.
BTW, this is using the stock filter base and lid.
Old Feb 12, 2007 | 09:58 PM
  #12
pg's Avatar
Thanks 73 Shark, I'll stop by the auto store in a few days. I have a stock carb, manifold and air cleaner. How about the screw for the wingnut, will I need a longer one?
Reguarding the engine I got GM's 10067353. They call it the "Universal 350". It comes with a 3 year, 50,000 mile warranty, 240 HP. I've put 26,000 miles on it in 5 years and it runs just fine for me. PG
Old Feb 13, 2007 | 12:07 AM
  #13
Yes you will need a longer stud. The stock one has 1/4-20 thread on both ends, so I bought a piece of threaded rod and cut it off 1" longer than stock. Works like a champ.
What are the specs on the "Universal 350"?
Old Feb 13, 2007 | 02:42 AM
  #14
pg's Avatar
4 bolt main block with 2 piece rear main seal.
Cast iron crank
LT/LT4 powered metal connecting rods.
Cast pistons (dished.)
Hydraulic flat tappet cam. (.383" intake/ .401 exhaust) and a 112-degree lobe seperation.
Cast iron heads with a 75cc combustion chamber
8.5:1 compression
GM claims 260hp and 350 pounds of torque with a 4 barrel and headers.
I cost about $1,600.00 and every thing bolted up in the same place with no mods. I kept the cast exhaust manifold and ran chambered exhaust under the car. It sounds faster than it is. PG.
Southern Shadow
Aug 9, 2006 06:02 PM
Paul
Jul 28, 2006 12:46 PM
71yellow454
Apr 4, 2006 02:57 AM
Clayton
Jan 10, 2006 07:33 PM
Jeff @Streetwerke
Dec 22, 2005 08:02 PM
