Door weather stripping
Old Dec 31, 2007 | 09:16 PM
shb3527's Avatar
Default Door weather stripping
Doors reguire to much force to latch following install of new weather stripping on my 74...any suggestions, or is this normal? complete resto near complete except inner door panels yet to install, doors shut fine prior to install of new rubbers.
Old Jan 1, 2008 | 12:27 PM
DeeVeeEight's Avatar
Banned
Default RE: Door weather stripping
As long as the door alignment is acceptable, I would not be concerned. The new weatherstripping will need time to compress and conform to the car's contours.
[sm=icon_cheers.gif]
Old Jan 1, 2008 | 12:29 PM
1974corvetteowner's Avatar
Hey welcome to the Forum. Personally I have not replaced the weather striping on my 74 but mine lso requires a bit of force to get the door to close all the way. But I am sure someone else on here will be able to help you a little better
Old Jan 1, 2008 | 05:07 PM
pg's Avatar
Hi shb3527, Happy New Year and welcome to the forum.Does it take the same force with the window down, if so then check the weatherstripping around the door, you may have to trim it a little.
If it closes better with the window down, then you can adjust the glass. PG.
GFehlman
Sep 22, 2007 08:57 PM
cyclic hardover
Aug 16, 2007 09:45 PM
tattoo
Aug 10, 2007 10:59 AM
placidthree
Oct 7, 2006 11:30 PM
Vet Head
Oct 14, 2005 07:01 PM
