Drop Down
Old Oct 28, 2006 | 12:29 AM
Gary's Avatar
Default Drop Down
Can anybody tell me what could cause the rear end to drop down when I put in in drive? The u joints feel good, the spring looks good I am STUMPED...........
Old Oct 28, 2006 | 12:36 AM
Default RE: Drop Down
First Gary, Welcome to CF.
Is there a "clunk" sound from the rear? If so, it could be the third member center support bushing is shot.
That's my guess!
Old Oct 28, 2006 | 02:42 AM
Gary's Avatar
Thanks Starship........Is that an eazy fix, or do ineed to drop the 3rd member......Yes there is a clunk Gary
Old Oct 28, 2006 | 02:56 AM
pg's Avatar
Yeah man, thats the way it happends in a automatic, just enjoy it, if your car just squats,& your ready when you see the green light. Go for it! PG
Old Oct 28, 2006 | 12:32 PM
Hey Gary,
Before you jump, an go buy that bushing, check out your rear end componants.
First!,Chock your front wheels!
Now jack up and put stands under the rear of frame. You want your suspension to hang free. Be sure that the e-brake is off and the trans in neutral.Now everything is loose.
Now you can get under and push, pull, and wiggle each componant. Inspect each componant at points of connection. (all nuts, bolts, etc.) Also take hold of your wheels, push and pull on the tops and bottoms, and sides.
Note any thing loose and go at it from there.
Dave
PS:
Use a floor or bottle jack to check the third member mounts. You only have to put enough pressure, to note if there is any movement. You don't want to take the weight off the jack stands. (bottle jack works best)
Old Oct 28, 2006 | 04:39 PM
Gary's Avatar
Thanks alot starship.......I will get after it and let you all know what I find..........Pic to come!...........Gary
Old Oct 28, 2006 | 05:27 PM
Question: Does the rear seem to move side to side, at all, when you take off from a stop?
Old Nov 8, 2006 | 10:20 PM
Gary's Avatar
No Side to side Starship..........But I changed that bushing you told me about, and that was a cure...THANKS
Old Nov 8, 2006 | 11:33 PM
[sm=smiley20.gif] You're Welcome Gary!
stlvet
Nov 19, 2007 06:31 PM
jmccormick
May 8, 2007 08:50 PM
PAY2PLAY
Apr 9, 2006 07:44 PM
deltb
Corvette C6 Z06
28
Nov 24, 2005 02:07 AM
