Electrical Problem...
Advance Auto (old Western Auto and Parts America) can check the alt, starter, and battery on the car. Maybe others, don't know.
Spend a couple bucks more and get a factory service manual from Helm. I got a Haynes and found it to be about on par with a Chiltons.
Edit: See I'm too late with the book advice but see someone else mentioned it also. More info is usually better tho. Very nice looking car. Does the nest-of -snakes side exhaust have the mufflers in it or have you even had a chance to hear it?
Correct. They are Hooker or Hooker look-a-like nest-of-snake header/side exhaust. They come with slip-in mufflers that are basically a glass pack without the outer shell. Supposedly they slip out and you can run open exhaust but usually once they've been in for a while, the rust holds them. You can remove the straight portion of the side mount tho.
NickD,
I am having the same problem with my 1979 C3 but it is taking about 1 week to drain the battery (4 from Advance so far). Follow the procedures on page 5-2 in the haynes manualfortroubleshootingthe chargine system. I have narrowed my short down to the CTSY CLK (fuse) circuit and I don't know what to do now. I am disconnecting each item in the circuit until the short goes away. No luck yet!
