Engine Problem...driving me crazy!
Old Jul 12, 2007 | 01:17 PM
  #11
RickStehr's Avatar
Default RE: Engine Problem...driving me crazy!
Old Jul 12, 2007 | 02:02 PM
  #12
SCHOON's Avatar
Sounds like your primary float is set to high, very easy to check.
Also could be your power valve, also easy to check.
I just got done fixing my 74 and I had similar problems.
All fixed now.
Old Jul 13, 2007 | 06:47 PM
  #13
RickStehr's Avatar
ORIGINAL: cwb
Ahem.
Mr. Stehr, you got duplicate posts here
https://www.corvetteforums.com/m_374..._/tm.htm#37485
and there no reason for a re-plyerto ask questions that someone else has already asked.
If we could close one of 'em there, mods...
You're fast....can't get one by you, huh?
Old Jul 19, 2007 | 01:50 PM
  #14
spanky01's Avatar
mine had a similar problem i had a vaccum leak on the distbuitor so after a while it was warm didnt wanna idle right and had a lag i re adjusted the timing and found a small vaccum leak that fix my problem
Old Jul 28, 2007 | 07:49 PM
  #15
Texas Jim's Avatar
Are your tail pipes black at the ends? Like it's running too rich? If the choke staysopen after the engine warms up, it will load up and want to stall until you get the revs up and the engine can burn the extra fuel. I'd say the choke is sticking. On the no 1st. gear thing, I'd say that you're not in gear. You are still in neutral as there's no way that 1st. gear (1st. speed gear)just doesn't work sometimes. Check choke for "sticking open" and "shift linkage adjustment." My best diagnosis. Good luck.
Old Jul 30, 2007 | 10:20 PM
  #16
Not to get technical TJ, but I think you meant to say check to see if the choke is sticking closed which would cause the rich condition like you said. Just wanted to be sure Rick looked for the right condition.
Old Jul 30, 2007 | 11:29 PM
  #17
Texas Jim's Avatar
Yes, the butterfly stuck shut. I meant the choke hanging, continuing to work. You're right, my wording was poor. Thanks.
EK vette
Apr 23, 2014 07:16 PM
scotitude
Sep 20, 2007 05:27 PM
EljayK004
Jul 21, 2007 11:11 PM
75 vette
Jul 6, 2007 08:46 PM
rjensen
Jan 11, 2007 12:40 AM
