Factory Alarm Problem
Old Apr 27, 2013 | 05:20 PM
Hondamaker's Avatar
Default Factory Alarm Problem
Hello,
Just bought a '76 corvette. It's all stock and has a factory alarm. But when I go to activate it, it just goes off. I lock the doors and turn the key on the side to turn on the alarm, and then it goes off and won't stop till I turn the key again. Anyone know how to fix this?
Thanks in advance.
Old Apr 28, 2013 | 09:30 PM
Check the door switches and the hood switch (if it has one).
Old May 19, 2013 | 05:21 PM
Bakaruda's Avatar
Could this switch be installed in the rear tail panel? My fathers car has a key switch in the tail light panel.
Old May 19, 2013 | 07:36 PM
They moved the switch from the tail to the fender in 75 or 76. It sounds like your problem is either the door or hood switches or the relay may be stuck.
Old May 20, 2013 | 04:42 PM
Did previous response on phone and didn't see your question. Answer is yes but you'd then have a hole in the fender to fill and paint.
Old May 23, 2013 | 06:53 PM
Bakaruda's Avatar
My car has this switch in the rearpanel. that is why I was wondering if it was insatlled there. Thanks the car did come with a factory alarm, now I get to try and find all the equipment to make it work again.
Old May 23, 2013 | 08:35 PM
I was wrong. They moved the alarm switch to the LF fender in '74 when they went to the rubber rear end. Not sure what your switch is but if it's connected to the alarm, then someone moved it. Check the inside of the front fender for a filled hole.
watwheel
Dec 26, 2006 11:24 PM
hombredog
May 23, 2006 02:10 AM
Superdzzz
May 6, 2006 12:39 PM
doc1
Aug 9, 2005 01:16 AM
Roadhack
Jun 10, 2005 03:11 PM
