Fast Idle - Vacuum Leak?
On the driver's side of the carb, I believe that there's a solenoid which on most cars was to control run-on when you turned it off. On early years, it was used to boost the idle when the A/C was turned on. That's why I asked if it has 12V with the key in the run position. If so, then that's where you adjust your idle speed. The idle screw on the carb should be set at the solenoid off idle speed or just something appreciably slower than your idle speed. That way when you shut it off, the solenoid allows the butterflys to almost close which prevents run-on or dieseling.
