Is this a good deal?
Old Sep 2, 2008 | 11:07 PM
corvette1976's Avatar
Default Is this a good deal?
1968 corvette convertible 427/435hp tripower. This is a project car that needs a total restoration. I am the 4th owner with owner history. 91k original miles. New Mexico car. Car has been disassembled and documented and body is on a restoration dolly. 2nd owner has buildsheet. Conv top frame in excellent shape. Hardtop is also in excellent shape. Frame is rust free. All components bagged and in boxes. Ralley wheels. Original shifter, 6500 redline tach and speedo ( 435 only ), screw in side yokes, sway bars, etc... NOT A 435HP CLONE!!!!
VIN # 194678S40xxxx,
Build date - Oct 19, 1967.
Paint - 976 Lemans Blue,
Trim - std Black,
Block - 3916321 correct date .060 needs rebuilt,
Heads - 3919842 aluminum L-89 heads. Not correct for car.
Crank - #6223 steel 427 crankshaft std-std,
Intake - original 3919852 build date 8-28-67,
Carbs - original/rebuilt center #4055 date 784, outer # 3659 dates 782, 794,
Rear end - FA code 3.70 Heavy Duty Positraction, original.
Distributor - 1111296 original, K66 with T.I. standard L-71
No dreamers please. Car is worth Big Bucks when done.$ 16,750.00
Also does anyone know if it is a 4-Speed Manual Transmission, close ratio, hvy dty how canyou tell.
Thanks.
Old Sep 2, 2008 | 11:21 PM
Default RE: Is this a good deal?
You can tell if it's close ratio tranny by turning the input shaft 2.2 turns and see if the output turns one turn. If it turns slightly more, then it's a wide ratio. As far as heavy duty (rock crusher), you'd have to see if it has straight cut gears or not. If it was driveable, you could tell by the gear whine.
Good luck on your sale.
all84vette
Apr 17, 2007 07:07 PM
FreadyZ22
Mar 14, 2007 12:13 PM
isracing
Dec 15, 2006 09:03 PM
zadious
Dec 5, 2006 01:51 AM
zadious
Nov 30, 2006 01:57 PM
