Help with stuck driver door
Old Jan 14, 2007 | 03:25 PM
Chryco_Psycho's Avatar
Default Help with stuck driver door
Ok so I am working on my customers 68 vette & I close the drivers door , I can no longer open the door , neither the inner or outer button releases the mechanism , I have the door panel off & the arms etc on the latch are all moving freely but the latch arm around the latch pin will not release
Any help is appreciated , Thanks in advance
Old Jan 14, 2007 | 04:36 PM
Default RE: Help with stuck driver door
Welcome to CF!
1. check to see that the lock mech is released
2. squirt a little wd-40 on the latch arm pivot
3. make sure the latch arm is attatched
My best guesses.
Old Jan 14, 2007 | 06:44 PM
Thanks for the welcome
I have tried all 3 , & I have tried jacking the car to close & open the door gap as well to see if it will release with pressure changes as the frame is tweaked , I have also tried to push in on the door to change the pressure on the latch , I have also tried to pry the latch up with the button pushed in fully , just looking for a solution short of a cutting torch or sawzall !!
Old Jan 15, 2007 | 10:38 PM
imjustsean's Avatar
unbolt the front hinges and try poppin it off backwards...its worth a shot.
Old Jan 15, 2007 | 11:21 PM
that could work ........itwont slide off forward though due to the wide lip on the end of the pin
No worky , I can get the hinge bolts insid eth edoor but cannot get the hinges out of the door without it being open
Old Jan 18, 2007 | 11:08 AM
imjustsean's Avatar
oh...thats gay. i dont suppose there is any room to get at the striker bolt and unscrew it or unbolt the lock mech. altogether...man thats a tuffy...i may have to brainstorm with my "expert"
Psycho212
Apr 2, 2014 08:12 PM
Toby
Oct 29, 2007 03:51 PM
williadg68
Jun 23, 2007 10:20 PM
corvette king
Nov 21, 2006 11:03 PM
b777_uk_2000
Aug 28, 2006 10:48 PM
