High idle
Old Jul 25, 2023 | 06:37 PM
tbrady52's Avatar
Default High idle
Hi
i having trouble with my 82 cross fire
idles high 1200 rpm I changed out TPS idle air sensor. IMAP didn’t change
pulled off the vac lines on the intake plugged them, the car idled around 600 less than a minute raced back up to 1200 rpms
I think the computer raised it up
Any help would be appreciated
also any mechanic near boston would be great
tom
Old Jul 26, 2023 | 08:56 AM
Welcome to the forums. TPS reset should be at.525 volts and make sure the throttle shafts are not worn. Some guys say after changing or replacing the TPS you should drive the car for 15 minutes or 5 miles to reset the ecm. Also check EGR for operation, some guys say to replace the engine temp sensor for the ecm, and check the thermostat to make sure its working. Check the idle control system to see if its clean and operational..
Old Jul 26, 2023 | 06:53 PM
You might check out the IAC valves to make sure they are operational and not gummed up. Check the tb base gaskets, making sure there are no vacuum leaks.
Old Jul 26, 2023 | 07:08 PM
tbrady52's Avatar
Default High idle
Thanks thomas77
I’ll check it out this weekend ( no golf for me )
carguylarry
Jun 10, 2009 07:55 AM
lbelew
Aug 6, 2007 09:08 PM
cobra3
Feb 16, 2007 01:24 AM
50annv03
May 18, 2006 10:07 PM
hangn7
May 15, 2006 09:30 AM
