Hood Air Door
Old Dec 27, 2008 | 03:36 PM
Redwhisper's Avatar
Default Hood Air Door
I am trying to figure out how the hood air door on my 75 works. I traced the wires and can get power to it, which makes it operate,however the manual shows a solinoid, which I can't locate. I also am not sure what switch operates the air door. When I got the car many wires were disconnected, so there has been alot of work under the dash, but this one has me perplexed. My guess is it connects to the switch above the throttle, so that when you put petal to the floor, the carborator will gets more air. How does the switch get power? Where is the solinoid located? Help will be appreciated.
Old Dec 27, 2008 | 10:09 PM
Default RE: Hood Air Door
The solenoid is up by the air door in the hood. The switch on a four speed is located by the accelerator pedal and is actuated at full throttle just like the kick down switch in an auto tran. FWIW I took my door and solenoid out so the cowl air is available all of the time.
Old Dec 27, 2008 | 11:32 PM
pg's Avatar
Hi 73shark and Happy Holidays, and a warm welcome to Redwhisper! Heres where it should connect, PG.
[IMG]local://upfiles/2883/A126C738C4DD4C8FAAD8C1889DC1B066.jpg[/IMG]
JeffM7344
Apr 20, 2008 09:35 PM
Zeeohsix
Corvette C5 Z06
Aug 23, 2007 04:13 PM
Black86vette
Apr 29, 2007 08:38 PM
white88
Aug 24, 2006 10:55 PM
jd2000
Dec 11, 2005 04:15 AM
