hood insulation pins
Old Jul 7, 2008 | 06:30 PM
orangevette's Avatar
Default hood insulation pins
A couple of the pins that hold the hood insulation have come loose from the hood. I tried using an epoxy cement to reattach them but that only held the pins for a very short time before they came off again. Does anyone out there know of a good adhesive to use to attach the pins to the hood? Any help is greatly appreciated.
Old Jul 7, 2008 | 06:48 PM
78buckshot's Avatar
Default RE: hood insulation pins
The factory may have used the bonding adhesive that is used for the fiberglass panels, just a thought since the pins are glued directly to the fiberglass hood.
Old Jul 8, 2008 | 03:15 PM
Try cleaning the old spot of any of the glue you used and roughen slightly and then wipe w/ lacquer thinner. After it dries, try using JB Weld epoxy. Have had very good luck with it.
Old Jul 9, 2008 | 03:59 PM
SCHOON's Avatar
After years of engine heat and weather changes the pins are doomed.
I picked up a new set on line and they stayed in with no glue etc.
Old Jul 9, 2008 | 08:54 PM
Just curious. What holds them on?
1974corvetteowner
Apr 28, 2008 10:09 PM
DeeVeeEight
Mar 1, 2008 06:44 AM
butchkim
Feb 9, 2008 09:20 PM
fullmonty
Corvette C6 Z06
Aug 4, 2006 08:06 PM
flower
Jun 23, 2005 02:57 PM
