Hood Latch
Old Sep 29, 2007 | 07:31 PM
rayluka's Avatar
Default Hood Latch
Oh boy, hope someone has a good hint here. Today I pulled on the hood release. Only one side popped. I pushed it back down and attemted to open again, now it wont open at all. Any ideas how to open externally? 1976 coupe
Old Sep 29, 2007 | 09:14 PM
Default RE: Hood Latch
Welcome to CF!
Not had the prob myself, but other posts say ya can reach it from under the car. Find the cable that crosses from side to side and pull it to open one side. Go up top, and with the one corner open, you can reach or hook the cable for the other side.That's what I've read. Sounds logical to me.
Old Sep 30, 2007 | 08:01 PM
gigabyte's Avatar
This has happened to me, but only one side. When the driver side popped I used a pair of chennel locks and pulled the wire...I was lucky. More important tho is the replacement cable I spend about $37.00 including shipping, was a cheap peice of junk and broke (the same as the first) after about six hood pops. I ended up repairing the original, which I should have done the first time. Anyway be careful if you have to replace the cable. Repro stuff sometimes is not so good.
Old Sep 30, 2007 | 10:52 PM
rayluka's Avatar
Totally impossible to access from under the car. Recived some tips on another forum but cant make it work. Guess Im headed to the dealer or a vette shop nearby
Old Sep 30, 2007 | 11:25 PM
pg's Avatar
Hi rayluka and welcome to the forum.
A dealer won't have a clue go to a Vette Shop.
That's the best I can tell you, PG
Old Oct 1, 2007 | 10:45 AM
You might try having two helpers push down on the rear corners of the hood and then pull the hood release.
When only one side popped open, which side was it?
steve47714
May 18, 2006 02:29 AM
becuzitsthere
Mar 9, 2006 03:56 PM
Robert
Feb 18, 2006 03:38 PM
Wifes81
Aug 12, 2005 12:28 AM
flower
Jun 23, 2005 02:57 PM
