Ignition system woes help needed
Old Jan 15, 2008 | 07:34 PM
  #31
78buckshot's Avatar
Default RE: Ignition system woes help needed
It should be a 12 gauge red wire with a white or black connector, it will only plug in one way on the cap, it goes in the " BATT " terminal.
Old Jan 15, 2008 | 09:17 PM
  #32
Rickcusaf's Avatar
I think I'm going to need to go to the parts store and buy a new connector and rebuild my connection. That red wire was rebuilt with a circular connector to slide over the blaster coil. Would you happen to know the name of the connector so I can look up a picture? Or have a picture of it?
Old Jan 16, 2008 | 09:36 AM
  #33
Rickcusaf's Avatar
She lives!
Old Jan 17, 2008 | 04:47 AM
  #34
78buckshot's Avatar
A little fuel, a little spark, it's amazing how much noise and power we can make. The tough jobs take awhile to figure out, the impossible ones just take a little longer. Did you find the proper connector, if not, JEGS has it, part #555-10550- $6.00. Glad we could help 'git 'ya back on the road.
Old Jan 17, 2008 | 07:41 AM
  #35
Rickcusaf's Avatar
sure did =) now all I need to do is bleed my brakes. The car sat for a month and a half and now the pedal goes to the floor. I've either got a bad master cyl, leaking caliper or stuff in the lines. Ah well. I've got the stuff and am going to bleed them today =)
Old Jan 17, 2008 | 12:26 PM
  #36
My money's on a bad master cylinder. []
Old Jan 17, 2008 | 03:53 PM
  #37
Rickcusaf's Avatar
I got lucky. The master cyl is good. The rear res had no fluid and a lot of air in the system. I've now got full power to the brakes. =)
Old Jan 17, 2008 | 04:36 PM
  #38
Glad that's all it was. Now the next question is: Where did all of the brake fluid go? []
Old Jan 17, 2008 | 08:05 PM
  #39
Rickcusaf's Avatar
I'm blaming the gremlins on that one. =)
Old Jan 17, 2008 | 08:32 PM
  #40
That'll work as long as the calipers stay dry.
bryanth73
Jan 19, 2009 08:09 AM
ddecker
Nov 11, 2008 07:49 PM
old mac
Jul 6, 2008 12:54 PM
veritek
Apr 11, 2006 10:43 PM
dcastine
Nov 22, 2005 07:16 PM
