Intermittent Window operation
Old Jun 26, 2011 | 01:13 PM
chevygrl79's Avatar
Default Intermittent Window operation
1979 corvette, we replaced the passenger side regulator and motor. Did not replace anything on the drivers side, as same parts were already replaced two months ago. Initially both windows will operate up and down when car is first started. For some reason, within minutes after car is started, both windows cease to operate up or down. After car is shut off for a few moments the windows will operate again. The only thing we are aware of that the driver and passenger window have in common is a fuse which has been replaced.
I have researched this in the forums and found that there is no relay past 1978. Additionally my dash lights when out at this same time, not sure what this might have to do with it. Any help in this would be greatly appreciated.
Old Jul 13, 2011 | 02:18 PM
daddysvett's Avatar
had the same problem, it was the wire that goes through the door, it was crimped so it was intermintent then just quit working.
Old Jul 21, 2011 | 07:02 PM
Welcome to the Corvette Forum to you both.
Wonder if there is a thermal switch that's opening up? Didn't know that they deleted the relay.
Bigboi
Apr 2, 2018 02:20 PM
RacingJunk
Oct 23, 2013 08:51 PM
gmk
Jun 19, 2008 06:44 PM
moscooter
Aug 3, 2007 10:37 AM
jefftwilley
Dec 9, 2005 12:11 PM
