lineing up the strut rod and half shaft
Old Mar 16, 2007 | 05:15 PM
whiteray's Avatar
Default lineing up the strut rod and half shaft
how do you line the strut rod to its housing and how do you line up the half shaft to the yoke?
my thought was to lift the trailing arm up but how theres nothing to lift it up by
Old Mar 17, 2007 | 12:35 AM
Default RE: lineing up the strut rod and half shaft
Hey whiteray,
Did ya get my PM?
My manual doesn't cover adjustable rods. The original rods had to be bent to get minor adjustments, that's why a lot of us have gone to the adjustable rods. You might have to use a combination of adjustments on the trailing arms and the rods to get an alignment to install the adjustable rods. Place everything in their original position of when you removed the stock rods, and the adjustable rods should reach.
Hope this helps Bro!
Old Mar 17, 2007 | 01:39 AM
The original rods should not be bent! There's an eccentric cam on the inner end for adjusting rear camber. If there isn't enuf cam to get camber in spec, then either the strut or trailing arm bushings need replacementor something is bent.
A lot of strut rods got bent by "alignment techs" because the cams were either frozen or it was easier. Probably the latter.
Old Mar 17, 2007 | 10:34 AM
ORIGINAL: 73shark
Very true, It's hard to find a "tech" that KNOWS how to align a Vette. [&o]
"The original rods had to be bent to get minor adjustments"
I should have explained that this is the general practice ofsome "alignment techs".
Sorry for the lack of a full explanation. My Bad! []
The adjustable rods make the job easier, and you can really fine tune the specs.
Although, it is good to use the cam adjustment to get 'er close.
Old Mar 17, 2007 | 11:00 AM
78buckshot's Avatar
Hey witeray, attach the strut to the trailing arm 1st, then either end of the half shaft, as you jack up the traling arm it will get to a point where it all lines up, the strut will be hard to get into the bracket at the differential and you may have to twist the rod in the bushings to line it up, don't tighten anything untill tou have all components in place, I used adjustable rods and I could see where it would be tough with the originals. If your rods are bent I would'nt use them.
hester
Jan 16, 2008 02:10 PM
bobbowtie
Jan 15, 2007 09:45 AM
harleyboy52
Dec 21, 2006 11:46 PM
jmtrotzie
Nov 14, 2006 12:39 AM
78vette
Nov 10, 2006 09:43 AM
