Need help replacing a radiator
Old Jun 17, 2008 | 04:44 PM
ebeard's Avatar
Default Need help replacing a radiator
I have a 75 convertible and the car has sat for many years. I replaced the hoses coming off the radiator because they were about to burst, but after i did that and fired it up the radiator kicked the bucket...So far i have gotten the fan blade and first half of the shroud off but the second half of it seems to be wedged between the radiator and upper A-arms. How do i get it out without cracking trhe plastic? This is my first vette to work on so any helpful advice for replacing the radiator is appreciated.
thanks
ethan
Old Jun 17, 2008 | 08:17 PM
Default RE: Need help replacing a radiator
As I recall, you can pull the rad and leave the bottom of the shroud in place.
Old Jun 17, 2008 | 08:18 PM
gigabyte's Avatar
You may not have to remove the shroud. it should pull away from the radiator emough to pull the radiator straight up and out. I replaced a 79 radiator and the shroud pulled toward the block enough to lift the radiator straight up and out. good luck
Old Jun 17, 2008 | 11:11 PM
Welcome to the Corvette Forum.
If you have A/C, you can either remove condensor or cut the bottom of the shroud in order to squeeze it together to remove it.
Old Jun 18, 2008 | 07:58 AM
Rich G.'s Avatar
I did a frame off restoration on my car and the worst part of the whole job was getting the radiator out. It aint a pretty job. Good luck
Old Jun 18, 2008 | 06:20 PM
ebeard's Avatar
thanks for all the help i got it out tonight with some difficulty...the bottom of the radiator kept getting stuck on the shroud and upper A arm but it finally gave way. After this the car is one step closer to a new paint job
thanks
ethan
Old Jun 18, 2008 | 06:31 PM
Good for you!
What color?
Old Jun 18, 2008 | 11:35 PM
ebeard's Avatar
the car is a father son project and he wants the yellow that they used on the 69s but i want to repaint it to its original white. Hopefully it will be done in the coming months and i can post some pics
Warren from Toronto
Oct 3, 2008 07:50 PM
synyster1
Jul 8, 2007 09:43 PM
txpd
Jan 2, 2007 12:00 AM
Bagpipingjake
Aug 21, 2006 11:20 PM
stang2x
Nov 15, 2005 10:38 PM
