Vin Decoder
Login with Facebook
rear end noise
1968 through 1982
rear end noise
11-10-2017, 09:54 AM
billyraymorrison
rear end noise
installed right side yoke in 1974 corvette.now there is a tapping noise in the rear end.What is the likely problem?
billyraymorrison
Find all posts by billyraymorrison
11-11-2017, 03:44 PM
73shark
Bearing, clutches,. . .? Never having done that operation, really can't help you. Maybe somebody else here will see this and put forward some ideas.
73shark
Find all posts by 73shark
73shark
73shark
01-24-2018, 01:30 PM
C3 Starship
Did you drop the yoke and have to put needle bearings back in place? Check your "U" joint for slack or miss alignment ( not seated properly in yoke)
C3 Starship
Send a private message to C3 Starship
Find all posts by C3 Starship
Engine Code
10:24 AM
