rear end noise
Old Nov 10, 2017 | 09:54 AM
billyraymorrison's Avatar
Default rear end noise
installed right side yoke in 1974 corvette.now there is a tapping noise in the rear end.What is the likely problem?
Old Nov 11, 2017 | 03:44 PM
Bearing, clutches,. . .? Never having done that operation, really can't help you. Maybe somebody else here will see this and put forward some ideas.
Old Jan 24, 2018 | 01:30 PM
Did you drop the yoke and have to put needle bearings back in place? Check your "U" joint for slack or miss alignment ( not seated properly in yoke)
