Oil pan replacement
Old Sep 10, 2018 | 08:39 PM
tamerakel's Avatar
Default Oil pan replacement
I need to replace my oil pan on my 1969 coup, it has a built crate zz454 engine with duel exhaust that does not cross the oil pan, will this be hard to do, or can I do while installed in vehicle, thanks
Old Sep 11, 2018 | 09:22 AM
It's relatively easy on a small block because it just requires unbolting the idler arm and dropping the drag link down to provide clearance. There is enough clearance to the crossmember that it doesn't require raising the engine. Not sure on a big block if that will work or not.
Old Sep 11, 2018 | 11:16 AM
tamerakel's Avatar
Ok thanks I hope someone else can chime in with a big block
Mark Achorn
Jul 6, 2019 11:46 PM
1974corvetteowner
May 17, 2008 02:12 PM
78buckshot
Jan 5, 2008 11:44 AM
drilr
Jun 26, 2007 06:10 PM
C3 Starship
May 30, 2007 07:31 AM
