Oil pan replacement
I need to replace my oil pan on my 1969 coup, it has a built crate zz454 engine with duel exhaust that does not cross the oil pan, will this be hard to do, or can I do while installed in vehicle, thanks
It's relatively easy on a small block because it just requires unbolting the idler arm and dropping the drag link down to provide clearance. There is enough clearance to the crossmember that it doesn't require raising the engine. Not sure on a big block if that will work or not.
