power steering
I was talking to a buddy the other day about the vette and power steering lines leaking and he mentioned something about the power steering pressure relief valve going on on these and causing the wheel to pull. Anyone had any issues with this?
Sweetness224, does your vette pull to one side or the other as you drive down the road?
If so you can adjust the valve. See http://content.mamotorworks.com/pdf/602452.pdf For a how to correct that problem.
Page 2 on the right.
The relief valve acts to regulate pressure. If you ever autocross or just try to turn the steering wheel very fast, you'll notice that you can't which is basically caused by the cylinder trying to push oil back faster than the relief valve can relieve it. The fix is to put a pickup truck valve in. The downside is a little loss of on-center control at highway speeds.
I have a 78 ford bronco with a 351m and the power steering pump is bad and i dont have the money to fix it right now but i have to drive it can i just take out the pump and drive it without it or will there be a problem, i mean besides it being hard to turn and whatnot, do i have to do anything to it to make sure it will work or will it even work?? can you guys help me please??...
