power steering
Old Mar 28, 2010 | 09:38 PM
Sweetness224's Avatar
Default power steering
I was talking to a buddy the other day about the vette and power steering lines leaking and he mentioned something about the power steering pressure relief valve going on on these and causing the wheel to pull. Anyone had any issues with this?
Old Mar 29, 2010 | 03:03 PM
SCHOON's Avatar
I had leaks and the same pulling problem.
Figure how old the car is and if the power steering componets were never replaced it's time.
Really not that expensive to do.
Old Mar 30, 2010 | 02:56 AM
pg's Avatar
Sweetness224, does your vette pull to one side or the other as you drive down the road?
If so you can adjust the valve. See http://content.mamotorworks.com/pdf/602452.pdf For a how to correct that problem.
Page 2 on the right.
Old Mar 30, 2010 | 08:20 PM
The relief valve acts to regulate pressure. If you ever autocross or just try to turn the steering wheel very fast, you'll notice that you can't which is basically caused by the cylinder trying to push oil back faster than the relief valve can relieve it. The fix is to put a pickup truck valve in. The downside is a little loss of on-center control at highway speeds.
Old Mar 31, 2010 | 08:53 PM
Thanks for the info guys. Awesome link PG, that helps a lot. Thanks Shark and Schoon!
Old Apr 1, 2010 | 06:21 AM
mikelangelo11's Avatar
I have a 78 ford bronco with a 351m and the power steering pump is bad and i dont have the money to fix it right now but i have to drive it can i just take out the pump and drive it without it or will there be a problem, i mean besides it being hard to turn and whatnot, do i have to do anything to it to make sure it will work or will it even work?? can you guys help me please??...
Old Apr 7, 2010 | 04:26 PM
You can just take the belt off the PS pump. The steering is going to be pretty heavy.
Can you afford a salvage yard pump?
lil red corvette
Jul 10, 2006 09:59 PM
forzav12
Jun 22, 2006 03:58 AM
jetmech09
Jun 8, 2006 09:49 AM
imb1987
Feb 8, 2006 12:38 PM
gs821
Jan 12, 2006 12:27 PM
