Power Steering Pump
Old Oct 26, 2006 | 04:07 PM
stlvet's Avatar
Default Power Steering Pump
I'm rebuilding the power steering pump on my '76 with a seal kit I got from ZIP products. My overhaul manual has a section on this, but I'm hitting a snag trying to separate the pump from the reservoir. The manual says to tap on the edge with a "soft" hammer. Has anyone done one of these and have any advice on getting the two parts separated? Should I pry it apart?
-thanks
Old Oct 28, 2006 | 06:38 PM
SCHOON's Avatar
Default RE: Power Steering Pump
I did it once awhile ago on another car and it did come apart.
Use a rubber mallet or something like that. Be careful if you try to pry it appart.
If you score the surface you will most likely get a leak.
vaelon
Aug 11, 2015 09:05 PM
614mobile
Sep 2, 2008 12:12 AM
gilsl82
Feb 24, 2007 01:44 AM
cabinetmaker
Oct 7, 2006 09:25 PM
gs821
Jan 12, 2006 12:27 PM
