pulling the 454??? Help!!!
Old Apr 1, 2007 | 11:46 PM
tomhawe's Avatar
Default pulling the 454??? Help!!!
I'm trying to pull a 454 from a 74 convertable4 speed. The engine moves about one inch from the bell housing and won't move any further. Never did this before and feelling quite impotent at this time........Anything I should know?.........Thanks!!!!
Old Apr 2, 2007 | 12:31 AM
Default RE: pulling the 454??? Help!!!
Welcome to CF!
Drop the tranny, you are quite possibly hangin' up on the clutch assembly.
When I pull an engine, I drop the tranny and pull the engine with the bell atached. Since you have the bell loose, you are most likely binding the tranny shaft on the clutch assembly, which is still bolted to the flywheel.
Old Apr 3, 2007 | 01:58 AM
Rich G.'s Avatar
You should pull the trans because you are going to bust your a__ trying to get the engine back in with the trans still in. I pulled my 454 out before I decided to take the body off but I pulled the trans out first and I still couldn't get the engine out until I took the bellhousing off also. I couldn't get the engine to lift up high enough to clear the motor mount brackets without having the bell hit the firewall. Not a whole lot of room in there with the manifolds and everything else on.
Old Apr 3, 2007 | 10:15 AM
With the tranny out, you can quite possibly tilt the front of the engine up, to get the bell to clear, but since you have the bell loose, all the better.
Old Apr 6, 2007 | 10:47 PM
I pulled the tranny with the engine but did have to tilt quite a bit. It's a lot easier to assemble tranny to engine out of the car.
Trooper
Jul 8, 2010 06:36 PM
tankerpilot01
Jul 15, 2007 12:21 PM
Camaro350Z28
Mar 23, 2007 12:35 AM
Phill
Mar 10, 2007 09:41 AM
86 Ironhead
Dec 26, 2006 04:45 PM
