Stripping Paint
Old Sep 14, 2007 | 09:35 PM
GFehlman's Avatar
Default Stripping Paint
What is the best product to help strip all the paint off my 68'? I want to get it down to the fiberglass.
Old Sep 14, 2007 | 11:24 PM
Default RE: Stripping Paint
unfortunatly....Sand paper. or media blasting with Baking soda.
Welcome to the site, Cheers
Old Sep 15, 2007 | 02:09 PM
AC's Avatar
AC
3 gallons of air plane stripper will do the trick....quicker than sanding and less chance messing up fiberglass. I check into the name of the (air plane paint stripper)friends have used on thier cars and where to find it.
Old Sep 16, 2007 | 09:59 AM
Although airplane stripper works wonders on painted steel , unfortunately, the methylene chloride in the airplane stripper will melt the plastic resin used to build the car. It's use will be very detrimental on anything formulated of plastic. Cheers
Old Sep 16, 2007 | 06:50 PM
SCHOON's Avatar
I am with Blueshark, go with baking soda. There is a guy by me that will blast a Vet for $700 and you will get your car back the same day with no paint on it.
Striping a Vet is a real nasty and sucky job.
Spend the $700 and your half way there.
Old Sep 17, 2007 | 07:45 PM
wrwalke's Avatar
The best tool for stripping several coats of bad Maaco $299 paint jobs off of a great Corvette? Drumroll... a wallet. Sandpaper works, baking soda in a blaster works, soft plastic bead in a blaster works... But I *highly* recommend paying someone with experience (and lots of it) to do the job.
bill.
Old Sep 17, 2007 | 08:02 PM
Ya forgot the cymbol crash, after "wallet".
Old Sep 17, 2007 | 08:39 PM
pg's Avatar
ORIGINAL: wrwalke
bill.
You and C3 Starship are so correct, a large stack of dollars and your car is good as new. PG
Old Sep 22, 2007 | 08:57 PM
Billm10454's Avatar
I used Captain Lee's. You can get it from Ecklers. You pore the fluid into a spray bottle that comes with the stripper and spray it on. It works in 5 to 15 minutes.
shb3527
Jan 1, 2008 05:07 PM
cyclic hardover
Aug 16, 2007 09:45 PM
tattoo
Aug 10, 2007 10:59 AM
placidthree
Oct 7, 2006 11:30 PM
Vet Head
Oct 14, 2005 07:01 PM
