Timing Gear
Old Feb 7, 2007 | 09:50 PM
copleychamp's Avatar
Default Timing Gear
I have 1968 327. I have done many timing gears in my 54 yrs, but i have never done a double roller. There are three keyways, O.E.M.,Advance,&retard. Since my dots on the crank & cam gear only line up on the O.E.M. keyway,how do i put the crank gear on? Do i just line my dots up pull the crank gear and put it at the setting i want? THANKS
Old Feb 8, 2007 | 12:03 AM
78buckshot's Avatar
Default RE: Timing Gear
hey champ, unless your running a pretty agressive cam, I would keep the timing marks lined up straight, you can allways advance or retard at the distributor much easier than tearing the front cover off .
Old Feb 8, 2007 | 01:11 AM
Advancing the ignition timing is entirely different that advancing the cam.
Old Feb 8, 2007 | 10:21 AM
1969 L46's Avatar
If you are running a basically stock 327, use the OEM alignment on thegears. There is no need to advance a stock or mild cam.
Old Feb 8, 2007 | 12:14 PM
sorry guys, i forgot to tell you about motor. 327, bored .30 over, flat top pistons, competion valve job, radical cam, heads are LT1 370 H.P. This car was built by second owner,a automotive engineer.It was built for street racing. I bought from 3rd owner who said he had it dyno at 430H.P. 400 ft lbs of torque. a double roller was on car when i pulled timing gears it was set on setting for low end torque. now im unsure how to put new gear back on like it was .THANKS
Old Feb 8, 2007 | 09:09 PM
mtkawboy's Avatar
Only a dyno will tell you if advancing or retarding the cam will help. Its all about trading high end HP numbers for torque. If you have the specs on the cam, the tools and the knowledge Id degree it to the manufacturers specs or see if the engine builder already did. Cam timing has nothing to do with ignition timing as was mentioned.
old mac
Jul 6, 2008 12:54 PM
yuggster
Aug 13, 2006 01:13 PM
jph
Feb 27, 2006 12:05 AM
josephgts
Feb 8, 2006 11:47 AM
jess_p
Nov 15, 2005 01:19 PM
