Trailing arm bushing replacement
Old Jan 16, 2020 | 08:18 AM
Bert Higgins's Avatar
Default Trailing arm bushing replacement
I'm replacing the trailing arm bushings on my 1971. I got the old bushings out except for what I'll call the "cups" that are still in the trailing arm. Instead of pounding these out, can I put the new rubber part of the new bushing and new center part in the old "cup" in place? I've read that the rubber component does the work. Thanks
Old Jan 27, 2020 | 11:14 AM
You not only need to remove that piece, you will need the special tool to compress the bushing while you flare over the tube that keeps it all intact. That tool can be purchased online from Corvette aftermarket suppliers.
ZZ4gorilla
Apr 29, 2013 08:32 PM
Sweetness224
Jan 9, 2009 04:42 AM
LT4Dave
Oct 12, 2008 07:25 AM
bruiserman
Sep 7, 2008 07:11 AM
thespannerboys
Oct 22, 2006 09:27 AM
